H@cKer said:^
Elite 334 is pretty good.
live2drive said:I am inclined towards CM elite 334/335. Can anybody shed some light on its pricing and availability in nehru place?
live2drive said:Picked up Elite 334 from SMC along with CM 90CFM Blue led 120MM AND amigo 80MM fans.:hap2:
SidhuPunjab said:^ CM has better paint quality, screwless mounting, no sharp edges, IIRC new revisions of Bijli has 80mm fan slot @ rear, also Bijli homeycomb mesh holes spacing sucks, will result in more noise + less airflow.
U should check Gigabyte case, GZ X2 etc is 1.5k~, same OEM, check Dealers section.
If visiting Nehru Place see Taiwaneese brand 'Matrix' case, very good VFM cases and solid built.
live2drive said:Thanx rockfella.
But the Power LED isn't glowing.
What should be done?? :huh:
live2drive said:Will check but I am pretty sure with the connections. Cross checked by reversing the polarity. But of no avail. Rest everything working absolutely fine.![]()
Rockfella said:Check with another mobo is u can.. maybe the cabbie light is kaput rofl!
live2drive said:LED is up and working. :clap:
Just tapped on it and wohoo, glowing glowing. :rofl:
