Guys this is what happened.....................
last month i bought a 500gb harddisk i removed the sata limiter in the harddisk
iv splitted it like this 35+85+350gb and
i installed xp in that drive it worked fine
2 days back i installed vista sp1
installations went fine
now this is ma problem .....after the startup..after 2 min or so if the system is idle its working fine if i do any work vista stops working that is the screen just pauses where it got stuck no mouse movement or anything...................
i ve installed sp1 twice and vista normal once they all have the same problem................... but xp seems to be workin fine..........................
is the problem lies with sata limiter ???
