Well I too have voltage fluctuation issues in my home. During peak time( i.e 7pm to 10pm) voltage go as low as 140v-150v. So my ups would stay in battery mode in those time. Occasionally voltage fluctuates during daytime too but only for a second. So I bought one electronics voltage stabilizer 1.5 amps(working range -100v to 270v). This with apc 500va ups worked flawlessly with my old P4 system. One month back I upgraded my system (see my siggy). With load on my rig even for small fluctuation during daytime that last for a second, my rig freezes. I could hear my hdd stop spinning at that time. Then i tried my system with x2 550+no gpu+no monitor plugged to ups. The issue almost solved. But ocassionally hdd freezes. Could this issue anyway related to non sinewave ups+ active psu incompatibility issue. I know its high time for a ups upgrade. But I not sure that it will solve my issue. Also I never heard overload beeps from my ups. Some say it is because of relay circuits in ups that cause a cutoff in current for a nanosecond that causes hdd to freeze during those voltage fluctuations. Also my new rig has wierd problems working inverter battery. The hdd stops every few second continuosly, whereas my old rig worked fine. BTW my inverter is Whirlpool Elantra 800va sinewave ups coupled with a prestolite battery. Is it because of the active psu in new rig compared to the passive in old rig. I enquired the price of online ups and to be frank i cant afford some 15k for it. So shall i go forward to buy a microtek 1kva ups (working range - 135v-270v). My old stabilizer wont probably work with new rig. For now i need my rig to work flawlessly well during daytime. I could sacrifice computing during those peak time for the time being.
Can someone explain what the issue really is? about why inverter not working well? about why hdd stop spinning? Can servo stabilizer 1kva+ 1kva ups solve my issue for 24x7 computing? Please help
~Akshay
~Akshay
