sidk47
Q: What is your budget?
• 80K.
Q: What is your existing hardware configuration?
1. LG Optical Drive.
2. Custom speaker set up.
Q: Which hardware will you be keeping?
Q: Which hardware component are you looking to buy?
1. Processor - Intel Core i7 920 D0 or 930 if 930 fits in budget.
2. Motherboard - Asus Rampage Extreme III.
3. Cooling - Thermal Take Ultra 120 Extreme(socket 1366) (I will consider only air cooling).
4. RAM - 3X2GB 1600MHZ (Open to recommendations). :huh: :S
5. HDD - Samsung Spinpoint F3 1 Terabyte SATA3 Desktop Storage 7200 RPM 32MB Cache.
6. Cabinet - Cooler Master ATX Case HAF 932 (RC-932-KKN1).
7. SMPS - Any good quality 750W(+) power supply (please recommend one with a economical price). :huh:
8. Monitor - Any good LCD/LED monitor for 15000->22000Rs (please recommend, would like a 16:9 aspect ratio and a maximum resolution of 1900X1200(or something like that.)). :huh: :S
9. Keyboard - Cheapest multimedia, considering Amkette.
10. Mouse - Cheapest laser wired, considering Amkette. But may go for a good mouse if the turning in GTA4 becomes smoother with a high DPI mouse. I don't know if this is the case as I think the turning in games like GTA is unsmooth due to the frame rate and not the mouse? Please clarify this for me. :huh: :S
11. GPU - Considering any generic/reference Nvidia GTX 460 1GB. This is because I will be adding a second card later in the future when the prices come down in order to SLI. Please recommend such a card at the minimum price as I can overclock it myself.
12. Steering Wheel - [OPTIONAL] Logitech Momo (Only if within budget, otherwise will buy later.)Q:
Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future?
• Yes, but it will have a budget of its own and will not be included in this 80K, planning to add another GTX460, nothing else.
Q: Where will you buy this hardware?
• Chennai - Ritchie Street. (PC)
• Coimbatore. (Monitor)
• Will be travelling to Chennai for a weekend for this reason.
• Not open to online purchase unless it is very much cheaper.
• No.
1. Gaming.
2. Browsing.
3. Download rig, 24x7 operation.
4. Watching HD movies.
• No particular prejudices strike me at the moment, but there is a very slim chance that they could strike when you guys start with your suggestions. But definitely not open to AMD processors, and prefer Nvidia GTX460 over ATI Radeon 5830 and the like.
1. GTA IV.
2. GTA Liberty City Stories.
3. Need For Speed Shift.
4. Colin McRae Rally Dirt 2.
5. Mafia II, etc.
• Gaming - 1900X1200.
• Desktop - Around 1024X768. Actually variable.
• Yes.
• Will overclock for games and normalclock for everything else to save power, extend processor life and de-stress the system. I really want to overclock as I want to play GTAIV as smoothly as possible.
• Windows 7 64 bit.
• Linux - Ubuntu Latest.
Please help me out guys. Am in desperate need of help from the PC buying experts. I will be getting this system for my 25th birthday on 14th October. Will be traveling to Chennai on 15th and 16th for the same. Your help is much appreciated guys…
• 80K.
• No.
1. Gaming.
2. Browsing.
1. GTA IV.
5. Mafia II, etc.
• Yes.
• Windows 7 64 bit.
