- Expected Price (Rs)
- 12345
- Shipping from
- Bangalore
- Item Condition
- 3 out of 5
- Payment Options
- Cash
- Bank Transfer
- Purchase Date
- Oct 1, 2013
- Shipping Charges
- Excluded - at actuals
- Have you provided two pics?
- Yes
- Remaining Warranty Period
- None
- Invoice Available?
- No
- Reason for Sale
- Not using it anymore
Hi Guys,
Have a whole lot of water cooling and modding stuff. So here goes:
1.Koolance QD's. These are for 1/2"/3/4" as far is I remember, but was using it with 3/8"/5/8". Two are compression and one is 1/2" barb (Rs. 3000)
Only 1/2" Barb one is left (Rs. 1,000)
2. EK Pump top for DDC Pump and a heavy pump stand (Rs. 500)
3. Whole lot of fittings. 3/8"/5/8" BP fittings, 90 degree fittings, 3 way dividers from BP and Koolance, stop fittings, fittings extenders etc. Some barbs and bits and bobs. (Rs. 3000) (One set of Barbs gone) Rest everything is available.
4. Heatmaster Alphacool, used for controlling fans pumps etc. Lovely bit of hardware. Has lots of sensors etc. You will need a power cable, which is essentially a printer cable, (Rs. 2,000)
5. VP 655T Alphacool pump and top, with the bottom plate for mounting, Essentially the same D5 Pump, with rpm, can be controlled with the above controller (Rs. 2000)
6.XSPC Raystorm CPU Waterblock. Used it with one of those liquid metal pastes on direct die, Works fine as is, but you can sand and polish if you want. Comes with last gen intel and AMD fittings (Rs. 1,000) SOLD
7. B&D RTX, the same as a dremel. Had imported it from the US and it works on US Power, so a step down convertor is required. If its a bangalore user, he can buy it with the step down. Cant ship it as its essentially very heavy. RTX alone can be shipped. Comes with some extra wheels and stuff. Crimper free...(Rs. 2,000)
Please note, all of this is used and will need to be cleaned out before using.
1.
6.
