FS: Power Cooling and Modding Water cooling gear - fittings, tubing, inserts, starter kit, radiators, Pump + Res
damn
Level D
Feedback: +9 / =0 / -0
Hyderabad
2 out of 5
  1. Cash
  2. Bank Transfer
Local buyers only
None
No
Eventually became busy with my job and didn't have the time/patience for a hard tube build. I ended up doing a soft tube build instead.
Product Name: Water cooling gear - fittings, tubing, inserts, starter kit, radiators, Pump + Res
Expected Price: Rs 15000
Shipping charges: N/A (I will not ship, pick up in Hyderabad only)
Manufacturer page URL: Pacific hard tube bending kit: https://www.thermaltake.com/pacific-hard-tube-bending-kit.html
3 units of EK water blocks hard tube fittings 16mm OD Nickel 6 pack: https://www.ekwb.com/shop/ek-quantum-torque-6-pack-htc-16-nickel
Corsair XD5 Pump Res combo: https://www.corsair.com/us/en/p/cus...es-xd5-rgb-pump-reservoir-combo-cx-9040002-ww
2 units of Corsair XR5 Radiator 360mm: https://www.corsair.com/us/en/p/cus...r5-360mm-water-cooling-radiator-cx-9030003-ww
4 units of EK Water block 16mm PETG tubes set: https://www.ekwb.com/shop/ek-hd-petg-tube-12-16mm-1000mm-2pcs
Alphacool hard tube bending heat gun: https://shop.alphacool.com/shop/hardtubes/biegetools/29111-alphacool-hardtube-heat-gun-pro-2000w
3 units of Aesthetic inserts for hard tube fittings: https://www.ekwb.com/shop/ek-torque-htc-16-color-rings-pack-red-10pcs
Plastic inserts for the EKWB hard tubing: https://www.ekwb.com/shop/ek-hd-petg-insert-12-16mm-10pcs
Description: I purchased a bunch of this stuff just before the pandemic, then I couldn't finish my build because GPUs were unavailable anywhere. So quite a lot of this stuff just remained in my basement. In the images there are also a lot of other accessories. I'll include the Corsair Hydro X fittings, Hydro X (AM4 compatible) water cooler, the appropriate sand paper needed to file the hard tubes, a PSU shorter plastic clip for watercooling trial runs. If you have questions, PLEASE ASK!!
Reason for Sale: Eventually became busy with my job and didn't have the time/patience for a hard tube build. I ended up doing a soft tube build instead.
Product condition: The products listed with the manufacturer links can be pessimisticly rated 8/10. In most cases it is never used. The free stuff might be in worse condition. Some special exceptions are listed below:
The Corsair Pump/Res was used in a rig for about 7 months, the condition of that is maybe 6/10.
Atleast one of the radiator has some dents, I did not leak test either of them. The condition is 6/10.
As a general rule of the thumb, you can assume that none of the stuff comes in original box.
The screws associated to some products such as the radiators, Pump+Res are unavailable. I have some assorted bunch of screws which MIGHT fit (and I'll include them) but please operate under the assumption that those are unavailable.
Purchase Date: Purchased at different times but the vast majority were purchased 02/12/2019
Remaining Warranty period: None
Warranty available in: None
Invoice Available: No
I'm in India only for a few days between 1 and 5th December, so I don't want to risk shipping. Pick up in Hyderabad is the only option. My intention is to avoid any kind of issues later on.
Please think long and hard before you make this purchase. There is quite some value here, but if you are newbie with water cooling, this is a bad idea for you.
This might also make a lot of sense if you want to flip the goods for a margin. Just the pump+res+radiators alone will cover the cost of what you are paying. But please be smart and calculated, bring leak testers/PSU if you can to test before you pick up. I would really hate for someone to plunge into this and be unhappy later.
