refills?
You mean that small green colour liquid that you mix with water?
Well that liquid is nothing but the coolant concentrate. Get some distilled battary water, and also buy some coolant from car shop. Mix them and use it. Works like charm
ohh dont forget to add few drops of savlon in it, prevents algae from growing inside your aquarious II
