zapout
Hi,
I'm facing problem with my system.
It's shutting down automatically, not shutdown per se...its more like a power cut. (no shutdown screen, straight to pc power cut)
It's happening randomly, sometimes pc runs for 3-4 hours with no issue and sometimes it power off 2 times in 3 hours.
It's started with artifacts/horizontal lines, pc lag and weird noise coming from pc.
Now its straight to power cut.. As if the psu is cutting power to the systsm.
Not facing other previous issues though.
I can't pin point it to any specific component, as it started with horizontal lines, noise and now power cut.
First I thought that its the hdd because of the lag and noise, now power cuts.
My best guess is, it's the psu.
I've cleaned the ram dimms, ran ram test, changed the thermal paste of the cpu.
Changes the power button connection to restart button (can't explained the logic behind why I did this[emoji52] )
I've halted my gpu purchase because of this.
Help me out guys.
Config-
-A10 5800k
-ASUS F2A55-M LK2 PLUS
-8gb(4x2) corsair vengeance 1600mhz ram
-1tb wd blue, 500gb wd blue, 500gb Seagate 7200.12
-seasonic S12II 520
Help me out guys.
Config-
-A10 5800k
-seasonic S12II 520
