Aman27deep
So the person who came to fit the LCD was correct - anyways thanks a ton !Gannu said:Yes. Sadly the same problem persists here as well.
dissel said:AFAIK, the back of the 3.5" jack of C Series SAMSUNG is not Headphone out, but rather it is a line out ----- So no control can be made by using TV's Volume control. Check with TV's Manual.
If you want to use HP you need a HP Amp (using Fiio E7 with HD 201 in C550).
