MY POWER PC IS ALWAYS ON – for weeks / months & I rarely shut it down. It goes into SLEEP Mode after 15 min [Using Win 11 Prof licensed]
I live in Mumbai (where power rates are highest in India) & using Tata Power Electricity. So how do I calculate the average power-watts consumption per month.
Note: I do not have a Power Watt Meter to Check accurate energy consumptions.
WHY I KEEP IT ALWAYS ON:
I have a problem of powering on my PC as the main Button of the Case/Cabinet does not work & I have by-passed it on the motherboard and then use a tiny start/reset button on the cabinet (with a ball point pen) – if required. This solution has worked well for the past 6 months or so.
Which is better Sleep Mode or – Hibernation & how to activate this? in Win 11
Is there an PC Energy Calculator - where I can assign the components of my PC to get the energy / power consumption?
This is my Configuration
i5-13600K | Gigabyte Z790 UD AX DDR5 | 64GB GSKILL TRIDENT Z5 6000MHZ | ASUS TUF GAMING GEFORCE RTX 3060 V2 OC 12GB | BENQ PD2700U – 27 INCH 2160p | ASUS TUF Gaming 1000W Gold Power Supply | Noctua NH-C14 | Thermaltake The Tower 900 Snow Edition with 9 Fans (NZXT & Vardar) | NZXT Hue+ with 7" Internal Monitor | WD Black SN850X 1TB M.2 NVMe Gen4 | NZXT LED Controller Hue Plus
Note: RGB Keyboard & Mouse also goes off in sleep mode. I also have 4 standard HDD's (totalling 11TB) plus 1 more 500GB SSD
