mannrak2003
- Q: What is your budget?
- Rs 500 /-for case fan,Rs 4500/- for sound card
- Q: What is your existing hardware configuration (component name - component brand and model)
- CPU - Intel Q8200 ,SLB5M
- Motherboard - MSI P-45 Neo-F
- GPU - Palit 9600 GT 512 MB DDR3,2*DVI,
- RAM - Kingston 2X2GB 800 MHz
- Monitor - Dell E1909W
- SMPS - Corsair VX450
- Cabinet – Zebronics Bijli
- Q: Which hardware will you be keeping (component name - component brand and model)
- Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
- Case Fan,120 mm – Scythe,Cooler Master,don’t know ?
- Sound card - Creative X-Fi Titanium Fatal1ty Pro
- Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
- Yes Maybe a TV /DTH tuner card in future
- Q: Where will you buy this hardware? (Online/City/TE Dealer)
- Open to online purchase
- Q: Would you consider buying a second hand hardware from the TE market
- Yes
- Yes
- Q: What is your intended use for this PC/hardware
- Gaming
- Browsing
- Desktop Processing
- HTPC
- Download rig, 24x7 operation
- Watching HD movies
- Gaming
- Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
- Slight preference for Scythe fans based on reviews read online
- Q: If you will be playing games then which type of games will you be playing?
- Race Driver Grid
- Dirt,Dirt 2
- Burnout Paradise
- Mass Effect
- Race Driver Grid
- Q: What is your preferred monitor resolution for gaming and normal usage
1.[FONT="] [/FONT]Gaming - 1280x728
2.[FONT="] [/FONT]Desktop - 1440x900
- Q: Are you looking to overclock?
.[FONT="] [/FONT]Yes
- Q: Which operating system do you intend to use with this configuration?
.[FONT="] [/FONT]Windows 7 64 bit
