What should I look for when buying an LCD monitor? If I were buying a CRT monitor I'd look for the screen size,
max. resolution, and the colour depth and refresh rate possible at that resolution.
But it seems to be different for LCD monitor. here's an example :-
LG L1515S Specs -
Brightness-250Cd/m2
Colors-16.2M
Contrast Ratio-400:1
Pixel Pitch(mm)-0.297(H)x0.297(V)
Resolution-1024x768
Response time-25ms
Viewing angle-160/140(H/V)
Mechanical
EMC-FCC-B, CE, VCCI-2
Ergonomics-TCO-99,ISO9241-3,7,8
Sync & Video
H-Scanning Freq-31-63 KHz
Sync Compatibility-Separate
V-Scanning Freq-56-75KHz
Video Input-RGB Analog
What does it all mean? Which all parameters should I consider while buying? Which of these values correspond to
Refresh Rate, Bit-Depth. etc?
Right now I don't do any gaming, but I might in the future.
LG L1515S Specs -
Brightness-250Cd/m2
Colors-16.2M
Resolution-1024x768
Response time-25ms
Mechanical
Sync & Video
