Shakensoul
Need a PSU for a very lower power/basic download rig, but the main criteria is it should be power efficient as it will almost run 24x7.
The only components right now will be amd athlon type cpu+ basic mobo and 1 HDD. Maybe later on will convert it into a media PC.
The PSU's that I have shortlisted are
1. Zebronics PRO 350W ~ 1.5k
2. Gigabyte Superb 460W ~2.2k
Max budget is 2.2k, but will the Gigabyte be an overkill for the basic rig ?
But not sure if the Zebronics is really power efficient. But cheaper the better
BTW, if anyone has a used above mentioned SMPS for sale, PM me
