Eazy said:"messa" .... I put an edit just for you in a post of mine above....
I asked the dude to get the Ninja HS's and he said he would check it out.... cross your fingers....
so ??? .... which one TT BT or Ninja ??![]()
Maxguru said:check this link .. 660W .. .ASK HIM IF HE IMPORT 2 UNITS
http://www.newegg.com/Product/Product.asp?Item=N82E16817103438
Phone: Meenal at 3295 0191
email: [email]meenal@primeabgb.com[/email]
too ecpensive i guess. not worth.. just came to know 660W is not that good.. ratings are bad...Eazy said:OK I can now mention that the importer of the Enermax and other stuff is Prime ABGB at Lamington Road, Mumbai
Phone or email at .....
Code:Phone: Meenal at 3295 0191 email: [email]meenal@primeabgb.com[/email]
I was asked to mention here that when people from TE contact them by phone or email you should mention that you are from TecEnclave forum for a better price.
The stuff he is ordering at the moment are...
Enermax - 500 and 600W SMPS - the 500 is expected to be below 6k
TT Big Typhoon
Nova mouse pads
Zalman 9500 and c77 and vga cooler
@Maxguru ..... Gulbir mentioned that he will be ordering 2 pieces of the Enermax SMPS you asked for - even if you do not want to buy them. The estimated price will be around 12.5k each -final price after he gets them in his hands.
Yup... as long as you don't have an asus board, Neo HE is absolutely fine. Don't go close to it if u wanna use an asus board.x86 said:udit neo he fan .. dont u see chaos is running x1900xtx , xfi with front bay hard drives fans bla bla wit tht neo he its awesome re .. get tht!!
y go for moon when u can have the stars :bleh:
Chaos said:Yup... as long as you don't have an asus board, Neo HE is absolutely fine. Don't go close to it if u wanna use an asus board.
Chaos said:^^It has incompatibility issues though seemingly the newer batches are fixed. Google for "NeoHE asus a8n problems" and you'll know why![]()
