Widows Vista Home Premium x86 Problem
mostwanted
Recruit
Hello,
I'm new here.
The problem is with updating Widows Vista Home Premium Service Pack 2(x86).
It does not update automatically or manually.
The Update Service says that I have 75-80 MB of update to be done but when I run the update, it simply doesn't download or install.
I have tried all the links that MS provides.
Please Help! :S
If you are using pirated OS, then you will not able to update sp2 but sp1 is possible through offline installers , if having genuine OS install sp1 first & then sp2 as mentioned above.
if you are getting too much issues. install a new copy of the os, don't do any *ahem* stuff, let it remain 30days trial, get genuine validation, install sp1 and then sp2, buy the os. :)
adi_vastava said:
how about downloading the SP2 manually and installing.
I have SP2.
The problem is with Automatic updates & installation, it always fails.
iyengar said:
Are you sure you have enough disk space? Are you sure you are running in Admin rights? Legit OS? I mean authenticated by MS?
eBro
Yes, I have enough disk space. Running admin rights & yes legit OS.
Yes, I guess I need to install a new. And this time I will buy Windows 7 and install. Vista is sloppy especially Service Pack 2.
Thanks to others for replying!
