blueyesdude
Contributor
Hi,
I bought a 3200+ and asus a8n-vm for my friend.But when i started the pc,
An error came up saying "Processor installed is of unknown revision.System halted".
Also the cpu fan was not running when i connected to the cpu connector pins.
It ran when i connected to the chassis fan connector on the board.
When connected to the cpu fan connector,the fan rotates when i loosen a screw on the mobo and when i just rotate the scew the otherwise it stops.???!!
Also when i held the motherboard in mid air it starts spinning and in the chassis it stops sometimes and sometime rotates.
The dealer told me to align the motherboard straight for it to run,But i never heard this kind of solution from anyone. I mean i assembled the mobo normally or is there any other special way to assemble this mobo?
