1)Go in your router setyings and make sure that:
hyeah:
a)it's setup as a DHCP server (Auto configuration)
b)That their is a starting IP adress and that there are several DHCP user numbers available. (50 is ok)
2)Check what IP your PC or PC's have so that you can set a free IP adress to the phone.
hyeah:
a)go to start, run and type: "cmd"
b)when it opens type: ipconfig/all and write down the "ip address"
and "subnet mask" and "default gateway"
3)Configure the phone as setup as above, but now configure the advanced settings.
hyeah:
a)On the phone go to: tools, settings, connection, acces point, open the lan connection you just setup.
b)click "options" in the WLAN Connection you setup and go to "adavnced setiings".
c)Go into ipv4 settings and set:
-phone ip address: (type one that is not being used by your pc, usually a digit higher)
subnet maskthe one you wrote down)
default gatewaythe one you wrote down)
Should work now.:cool2:
Enjoy!:hap2:
