Wired noise cancellation earphone
Have a long flight coming. Need to listen to my audiobooks.
- Wired
- noise cancellation - passive or active
- cheap : This will be like a 1-2 time use.
- Sound quality not important.
- Comfortable.
Thanks!
I have the CCA Lyra from Headphone Zone, and I quite like it. Would recommend.
The silicone tips they're provide give me good enough passive noise cancellation for public transport noise and I've found these to have a good bass and vocals so audiobooks and pop music sound decent through these.
If you don't like the silicone tips, or want something with a firmer grip, try some foam tips.
As a bonus, this has a great mic too.
If you already have over-ear or on-ear headphones, you can use it with 3M ear plugs acting as passive noise cancellation.
define cheap.
bought a renewed jbl c100si for 242INR in July 2022 [New available for 548INR now]... working very well till now.
