Wireless connection problem.
Yrus
Inactive
Contributor
I have a Zyxel Prestige 660R-T1 router(1 Ethernet port, no USB port) and a Linksys WRT54G Wireless router,
Now I have 2 PCs, one in my room and one in the hall, the hall one has a wired connection meaning the phone line is available there, my room does not have any phone wiring, so I must use a Wi-Fi connection,
**Room PC - Must use wireless, no phone wiring
**Hall PC - hall has phone wiring, so can use wired connection here
1. Now how do I setup the wireless connection?(Only 1 Ethernet port in the Zyxel router)
2. Will the setup be of a server and client form? I don't want this sort of setup, because then one system will have to be ON if the other is to access the Wi-Fi connection,
3. Can I have my room PC access Wi-Fi and the hall PC connected to the Ethernet port of the Linksys router(it has 4 of them)? Will the room PC be able to access Wi-Fi if the hall PC is kept OFF?
I hope you understood my query :P , thanks.
Ok, I managed to setup the connection,
The distancel between the router and my room is around 43feet with 2 walls in between,
Now I need a Wireless Card, should I go for PCI or USB?
