Storage Solutions Writing Problem Help Plz !!!
ishnk
Novice
Hey Guyz Plz Need Help Desprately.
I Brought A Lite On Dvd Writer Which Is Giving Problems.
My Buffer Level In Nero Not Constant At 100% Or Not Even In 90% Ranges Wht Should I Do Plz Help Me :( :(
ok lol see dude you must have clicked on verfify after writing option!
plxz check!
uncheck the option verfity and every thing is normall BOOm to 12-15 min :hehe
Agreed with Ankit...Check ur cables....seriosly it matters..
My 40 pin cable used to get hot like hell..!! plus it used to take exactly 1hr for a DVD to get burned....ITs all solved with latest drivers and 80 pin cable..;)
