Xigmatek Led 120mm & 80 mm: Cooling System XLF Series- High Speed Low DBA (20)
mediahome.in
Inactive
Contributor
Feedback: +185 / =0 / -2
Xigamatek XLF-F8253 (80mm) - 425 Shipped
  • Specific bearing design (Long-life bearing) provides longer MTBF and outstanding performance.
  • Optimal blade design provides the reduction of noise and power consumption.
  • Transparent colorific blade and frame with White-LEDs make your case a spotlight.
  • Higher airflow, static pressure and torque.
  • Reduce noise and power consumption
  • 4 pcs White LEDs and transparent colorific blade and frame
  • Low noise level.
  • Longer life bearing design.
  • Optimized blade design to create cooling performance
  • Product Name ‧ XLF-F8253
  • Product Number‧ CFS-S8GJS-LU1
  • Dimension 80(W) x 80(H) x 25(D) mm
  • Voltage Rating 12V
  • Speed 2200 R.P.M.
  • Bearing Type Long-life bearing
  • Air Pressure 29.2 CFM
  • Life Expectance 50,000 hrs
  • Noise Level <25 dBA
  • Available color ‧ 4 white LED (Orange Fins)
  • Connector ‧ 3 Pin
  • Accessory ‧ 4 pin adaptor
  • ‧ Screws*4
Xigmatek XLF-F1253 (120mm) - 500 Shipped
XLF-F1253, 120mm LED cooling fan catches not only your eyes, but it also performs adding more airflow in your PC case. It comes with max 1500 RPM and 61 CFM and also with quite level (<20 dBA). Shinning LED light and transparent colorific frame/blade make your PC case a spotlight. To make your PC case a spotlight and outstanding performance, XLF-F1253 is the optimal choice.
  • Low noise level.
  • Product Name ‧ XLF-F1253/54
  • Product Number‧ CFS-SXGJS-LU1
  • Dimension 120(W) x 120(H) x 25(D) mm
  • Speed 1500 R.P.M.
  • Air Pressure 61 CFM
  • Noise Level <20 dBA
  • Available color ‧ 4 white LED (Orange Fins)/(Black Transparent Fins)
  • Connector ‧ 3 Pin
  • ‧ Screws*4
Wow its been only 2 mins after posting and we got a buyer :D.., will be getting one this week :)
@pappu : look @ the top for prices.
