    Sincerely,
    The TechEnclave Team
FS: Home Audio Video ZoomGo Wifi Media Stick 2 USB Port Car Charger (max 2.4A each), total 3.4A
raksrules
Navigator
Feedback: +13 / =0 / -0
Mumbai
3 out of 5
  1. Cash
Excluded - at actuals
none
No
Not using, clearing stuff at home
Product Link for reference: https://www.walmart.com/ip/ZoomGo-WiFi-Media-Stick-Car-Charger/945992604
The device is a USB car charger with 2 USB ports and max current per port is 2.4A but total is 3.4A. Only USB-A ports. Additionally, it is also a Wifi media stick to be used in car, wherein you can install a MicroSD card (tried max 128GB, not included in the sale ) and the content from that will appear in the ZoomGo app.
The zoomgo app is NO LONGER AVAILABLE officially on app store or playstore. On my android table Samsung galaxy a7, I downloaded from apkpure and it was crashing because it told me the app is made for older generation android. I then installed the app on my FireHD 10 from 2017 and it worked fine (pictures attached).
The device has a MicroUSB port to use at home but I found that it is little finicky as not all MicroUSB cables worked with it (my microusb cable, part of 3 in 1 cable is also not good anyways), may be something to do with length of actual male part on cable. But I have a cable that worked fine and I am sending that too.
Inside the car, which is the primary use of this device wherein it works from car's port, it works absolutely fine. Charging of phone etc works fine too. You need to connect to the Wifi signal this device transmits to be able to access content on the installed MicroSD card.
