- What is your budget?
- 20K
- CPU - Ryzen 5 2600 w/ stock Wraith cooler
- Motherboard - MSI B450M PRO-VDH MAX
- GPU - GTX 980 FE
- RAM - 2x Hyper X 8GB DDR4 HX424C15FB2/8
- Monitor - Dell FHD 24" 60Hz
- PSU - Corsair RM750
- Storage - 1TB Intel SSD SSDPEKKF010T8
- Case - CM Qube 500
- GPU - GTX 980 FE
- CPU - Pre-owned Ryzen AM4 CPU
- Motherboard - Any pre-owned S or A tier motherboard
- RAM - Pre-owned RAM that is above 2400Mhz
- Monitor - If my budget allows
- PCIe 4 NVMe drive - If the new motherboard supports and my budget allows
- Any other recommendation
- No, I won't be able to upgrade the following within 6 months
- Mumbai (Delhi, Bangalore or Chennai by contacting friends if there's a good deal)
- Open to online purchase
- Competitve Games
- Browsing
- Download rig, 24x7 operation
- Watching HD movies
- Do not want to buy Intel because of only 2 years of motherboard support
- CS:GO
- Valorant
- Gaming - 1080p
- Desktop - 1440p
- Yes if possible
- Windows 11 64 bit
As much as I'd like to switch to the AM5 platform, I'd have to buy a 17k CPU + 10k MB + 3k RAM. Also please don't tell me to wait and save up as I am done waiting.
- Windows 11 64 bit
