Budget 41-50k Need gaming CPU under 50k | Ryzen build
Kiran G Abraham
New Member
8
0
1
    1. What is your budget?
      • 50K
      • CPU - Intel i5 2500k
      • Motherboard - Intel® Desktop Board DP67BGB3
      • GPU - xfx amd radeon 6870
      • RAM - corsair 4gb x 2
      • Monitor - Dell IN2020
      • PSU - Cooler master rs600w
      • Cabinet- Cooler master usp300
      • HDD - WD 1 TB x 2
      • HDD - WD 1 TB x 2
      • Yes, will upgrade the following within 1 year
      • Monitor - need suggestions
      • PSU - 600w better psi from seasonic or corsair.
      • Cochin / Bangalore
      • Open to online purchase (need suggestions)
      • No
      • Gaming
      • Designing
      • I don't like the Cooler master pc case since it is too common.
      • FPS - Destiny 2, Anthem(waiting eagerly for release), COD WW2 etc
      • Racing - Crew 2
      • Online - overwatch etc
      1. Gaming - 1920x1080
      2. Desktop - 1440x900
      • No
      • Windows 10 64 bit
bssunilreddy
Veteran
Mar 24, 2007
2,085
810
207
41
Nellore
plus.google.com
Budget -54K
AMD Ryzen 3 2200G -8700,
MSI B350M-Pro VDH -6300,
Crucial Ballistix Elite 8GB DDR4 3000MHz -6,200
Zotac GTX 1050 Ti 4GB Mini -14800,
Corsair CX 550 -4500,
Antec P8 Transparent Side Panel -4000,
LG 22MP68VQ-P 22” LED IPS -8500, (paytm mall)
Logitech MK200 -1000.
Total -54,000.
A Samsung 860 EVO 250GB SSD @ 6.2k from onlyssd.com is also recommended. But you don't have enough budget.
Never use Cooler Master PSU like Cooler Master 600W and the monitor Dell IN2020 is not at all sufficient.
So suggested the best within the budget.
All prices are taken from mdcomputers.in
Kiran G Abraham
New Member
8
0
1
Budget -54K
Total -54,000.
Thanks a lot @bssunilreddy.
I was considering to buy an amb 2000 series apu, but heard tat the motherboards bios needs to be updated and tat is not the very best option as of now.
Shall i get another psu like fron corsair. I mean will my build get ruined if i go with my old one.
bssunilreddy
Veteran
Mar 24, 2007
2,085
810
207
41
Nellore
plus.google.com
Don't worry as the mobos are getting updated before being shipped out to the end users.
That CM PSU might start a fire in your PC. So not at all recommended.
Even it can cause the life span of your components to decrease.
Don't ever go with Corsair VS Series PSU's.
Reactions: Crapmypants
Kiran G Abraham
New Member
8
0
1
Wokies. No corsair vs series.
Will go for the cx 550 only. Thanks for the timely advice
6pack
ex-Mod
Sep 19, 2005
7,762
1,695
302
if he does not buy the monitor he can save 8k.
disregard that. all over the world Dell is selling this monitor with full hd resolution. In india its just 1600x900.
so he'll have to buy new monitor too. Just sell off the old pc on olx or something to get some money for the upgrade.
Kiran G Abraham
New Member
8
0
1
@6pack thanks. So i guess i have to buy a new monitor too...
Any budget suggestions.[DOUBLEPOST=1521861944][/DOUBLEPOST]
Isn't the cabinet a bit overkill for your build ?
@Him yup. I have decided to go with nzxt s340 elite vr version. Hope that will fit in nicely with the budget price range and the looks.
But open to suggestions
6pack
ex-Mod
Sep 19, 2005
7,762
1,695
302
You have the monitor right? What resolution does it show in desktop settings? If its full hd no need to buy a new monitor. If its not, only then buy the one mentioned by bssunilreddy.
I don't have any suggestions on the config right now. Instead of getting a keyboard mouse combo, get them seperate. The logitech mouse has only 1000 dpi. I've seen HP X1000 Wired Mouse with 1600 dpi on sale on Amazon for 288. For only keyboard you can buy Amazon basics keyboard for 599.
Him
Active Member
175
25
41
At what price you're getting the S340 Elite version ? I have seen them selling for 8.1K which in my opinion is a bit overpriced.
Kiran G Abraham
New Member
8
0
1
Yup that is the price in amazon primeabgb and all.
So i have a 32 inch sony led with me.. I can use it as a monitor right?
Him
Active Member
175
25
41
For the case, If you don't care much about looks then you can go with either Corsair 270R at 5K or 400C at 6.8K. For the PSU get Corsair TX550M it is 80+ gold certified and comes with 7 years warranty.
6pack
ex-Mod
Sep 19, 2005
7,762
1,695
302
Yes, ofcourse. I have connected my 32" Sanyo LED tv to my NUC. It works like a big monitor. No difference except the extra brightness and size.
ironhide1
New Member
3
1
1
Your existing setup with 2500k is still good enough for most games with upto nvidia 1060, save money and upgrade them later , check youtube for benchmarks
GPU prices are crazy stupid high noww :mad::mad:
1060 3gb version isn't good investment for future because of low VRAM , avoid it
>> either Gtx 1050TI 4gb - 15000 or 1060 6gb ~~ 28000
>> Corsair Tx 550M ~~ 6000
>> Monitor ( if needed )- LG 22Mp68Vq ~~ 9500
> it is better to buy 1050ti now if you are thinking of upgrading to next generation GPUs from Nvidia and Amd next year when hopefulyy all these high GPU and Ram prices come crashing down :rolleyes::rolleyes: but check benchmarks first
atiamd
Aug 20, 2009
846
101
132
34
Juicy Way
GPU prices have started to come down in the US. Check Newegg and Amazon US. Wait for a month or two for the prices to fall in India too. Just for your reference, let me give you the prices of GPUs as they were before the mining craze:
GTX 1050ti 4GB - Zotac - ~11000
GTX 1060 3GB - Zotac mini/AMP - 17000/19000. One time, I even saw a mini for sale for 13k on Amazon in a lightning deal!
GTX 1060 6GB - Zotac mini/AMP - 23000/25000 - In an ideal world they should be around 19000/21000
RX 480 8GB - 20000 is the cheapest I saw back in Feb 2017
RX 470 - 4GB - 17000 is the cheapest I saw back in Feb 2017
GTX 1070 - Zotac mini/AMP/extreme AMP - 35000/38000/40000 or so
Above are the prices that were "normal" a year back. If one has to buy them today, they should be 10% cheaper given that the electronics usually drop prices as time goes by. However, around May last year, this whole crypto craze swept the GPUs off the market forcing us to spend exorbitant amount of money. I bought my mini 1060 6GB for 23k in Sep 2017 when the GPU prices fell down. Around Oct or Nov 2017, RAM prices increased and crypto craze increased again, due to which GPU prices have again increased so much.
I want to sell my 1060 to make money off of it or break even, but my idealism is not letting me to. :p
manju_rn
Active Member
153
39
41
45
Kiran G, I am not sure why you are advised Ryzen 3 2200 where the better option would be Ryzen 5 1600 (or 1600 X, I see that you had 2500X, you I assume you are interested in overclocking). 1600 far exceeds 2200 or even 2400, also, buying a dedicated GC completely kills off the reason for 2200 or 2400. Yes 1600 may be a bit pricer than the 2400, but trust me, it is worth all the money. You may want to check out the benchmarks.
Kiran G Abraham
New Member
8
0
1
@manju_rn Thanks. I have purchased ryzen 1600 and am eagerly waiting for the other components to arrive.. Thanks to all of you for the support and suggestions. Will post the full component list and will post some pics once i complete the assembly.
manju_rn
Active Member
153
39
41
45
Super. Njoy the new PC. Do let us know if you need help in assembly
