Amazon fire TV 4k or 4k max: reviews needed
It can replace on/off and volume buttons for most TV’s
thank you.
ordered amazon certified refurb 4k max for 3600. felt like a good deal: Certified Refurbished Fire TV Stick 4K Max streaming device, Wi-Fi 6, Alexa Voice Remote (includes TV controls) : Amazon.in: Amazon Devices & Accessories
Yes. My TV remote is in some random drawer right now. I am exclusively using Firestick 4k remote for the on / off feature.
But be aware that, my firestick is old so I am unsure if 5 years back they had the remote with power button or not. The remote I use currently is an aftermarket remote I got for Rs. 250 from nearby electronics shop. It works well and does the on / off well. Did not need to make the remote “learn” using old remote and yes volume up/down too works.
No! No! No! Don’t buy the MAX. The newer fire stick is much better. I linked it above. It is 3999 with a 500 coupon.
umm…all reviews suggestsed that max is faster and I cant make sense of the version and release dates from listings really. from the same series, max would be better…right?
Amazon Fire TV Stick 4K | Alexa Voice Search, Cinematic 4K streaming with HDR10+, Wi-Fi 6, Dolby Vision/Atmos (newest model) : Amazon.in
Cancel the order and order the other one , Simple.
ok, I did cancel the order but whats the difference between the 2? I mean why would you say 4k is better than 4k max?
As mentioned earlier, the one available in India is the older Max version. Better to get 4K.
There is also an Amazon Pay reward which gives additional 150 off. Plus if you reach 5k, you can get 10% off with HDFC cards.
sorry, not trying to be an idiot but I didnt see any difference in specs. this is what claude says about older 4k max and newer 4k device. is this not correct?
The Fire TV 4K Max is better than the newer regular Fire TV 4K. Here’s why:
Performance: The 4K Max offers noticeably faster menu navigation and app loading times Tom’s Guide
It has a 2.0GHz processor and 2GB RAM compared to the 4K’s 1.7GHz processor and 1GB RAM, loading apps approximately 13% faster HomeTheaterReview
Storage & Connectivity: The 4K Max has 16GB storage (double the 4K’s 8GB) HomeTheaterReview
and features Wi-Fi 6E tri-band support while the standard 4K uses Wi-Fi 6 dual-band HomeTheaterReview
Extra Features: The 4K Max supports the Ambient Experience, which allows your TV to function as an Alexa device with curated art backgrounds, weather, time, and customizable widgets Best Buy
Picture & Sound: Both devices are identical for actual streaming quality - they support the same 4K resolution, HDR formats, and Dolby Atmos Tom’s Guide
You have a choice: You listen to Claude or you listen to us! In any case, good luck with your choice.
ok. Thanks. I will try to do some more research on actual specs I suppose.
While I do trust real people more than Claude, hard to ignore facts over opinions (amazon has not made it easy to validate facts in their listings though). Anysway, thanks for your time in responding to my queries so far.
You are comparing 4K Max (Gen 2) (2023 release) and 4K (Gen 2) (2023 release). However, the one available in Amazon India is 4K Max (Gen 1) released in 2021.
4K Max (Gen 2) if available is a good buy, but it is not available.
Max has different versions , check which version you are getting and the exact hardware it has. As called out above.
Thanks so much man. Yeah, that makes sense. amazon has listed details pretty poorly in both the listing TBH. wonder if that’s intentional :grinning_face_with_smiling_eyes:
Yeah, Thanks. this makes sense. amazon is being vague about it in listings I suppose. will reach out to customer support.
There are two versions of the Fire TV Stick 4K Max: the first generation, released in 2021, and the second generation, released in 2023. The 2nd Gen is an upgrade with a faster processor, more storage (16GB vs. 8GB), and Wi-Fi 6E, while the 1st Gen runs Fire OS 7 and has Wi-Fi 6. Both versions can stream in 4K and support various HDR
formats like HDR10, HDR10+, and HLG.
Fire TV Stick 4K Max - 2nd Gen (2023)
  • Storage: 16 GB
  • Wi-Fi: 6E
  • Processor: 4x ARM Cortex-A55 at up to 2.0 GHz
  • Operating System: Fire OS 8
Fire TV Stick 4K Max - 1st Gen (2021)
  • Storage: 8 GB
  • Wi-Fi: 6
  • Processor: MediaTek MT8696 at 1.8 GHz
  • Operating System: Fire OS 7
The devil is in the hardware specs and the details, Check those and validate once before buying.
How do you know what Claude is saying is a fact? Everything about AI is an opinion and a lot of times, it is “confidently incorrect”. There is no fact or fiction for AI. That is the way models are built. It is only an opinion.
sorry man, you are helping me and I dont really want to sound like an unappreciative asshole but just trying to clarifying what I was saying. :slight_smile:
I was saying Claude is giving me stuff which it claims to be facts and I need to validate them which amazon is making hard to do. What you were giving me was pure opnion which I respect but would have preferred to know basis behind those. I appreciate your opnion though and I understand that you are not obliged to be give be the basis for those onions. I have decided to go for non max version now based on the information you and couple of other members have provided here. :slight_smile: so thanks.
No. What Claude was doing was giving pure opinion. I told you the reason in my post above (quoted below).
I didn’t realize that people trust these AI systems so much that if it claims to be a fact, you would believe it. Even when I do google search, I always go to the source to see if it is legit. I don’t know how people can believe whatever the AI spits out.
