Well i used torrent storm b4 and now shifted ove to azeureus..the trouble with azeureus is tht it runs ok…but if smhow i get disconnected in between or get logged off the net..with azereus still running…when i get connected/logged in and azereus resumes the dloads it takes the cpu usage at 100%…
any 1 knows any solution to this?
I have heard this befor I think you can change the settings somewhere in the program. (I haven’t used azeureus in a long time) I use BitComet now.
Yup since it is based on java azureus takes up the cpu usage to almost 100% when you start a torrent etc since it also starts allocating disk space to the torrent. No solutions to it as of now, you will have to live with it.
Switch to BitTornado instead, based on Bit Torrent. ![]()
Bit comet is the best choice.
though it may be characterized as a leech client by some sites
