This is the EKWB LOOP LEAK TESTER FLEX (LATEST MODEL STILL NOT AVAILABLE IN INDIA OR is Available ONLY through Sites that will Import the Product for You & Payment in USD)
This is a fast and safe way of testing for possible leaks in your liquid cooling loop. One end is fitted with a revolvable male G1/4” connection port so it can be directly screwed into any standard port in your liquid cooling loop.
The other end is hooked up with a non-return valve which will make sure that no air is escaping through the tester unit itself.
**It can be used with ANY other brands of LIQUID COOLING LOOPS too as it can be directly screwed into any standard port in your liquid cooling loop.
While traditional leak testing works, it requires hours before very small leaks are detected and then things can become messy. The EK-Loop Leak Tester Flex does the job within minutes.**
[Product Link](’
https://www.ekwb.com/shop/ek-loop-leak-tester-flex’
[YouTube](’
https://www.youtube.com/watch?v=b_zsMjQhQLg’
Ordered directly from EKWB SLOVENIA [Total cost paid Rs 10150 – Inclusive of Customs Import Duty/Taxes as on June 12th – 2022]**
NOTE:
I apologise if the Date Stamps are old on the images posted – Reason being I lost my One Plus Phone on 5th March 2023 and thereafter – Both my Google & FB ACs were compromised. It has taken me awhile to restore everything & TechEnclave was kept in the loop.
I GUARANTEE A FULL REFUND IN CASE THE PRODUCT ON OFFER DOES NOT FULFILL YOUR NEEDS & Will Personally Bear the Cost of Return Shipping Charges.
THIS PRODUCT IS OFFERED AS A STANDALONE OR WITH – [EKWB DUAL LOOP COMPLETE KIT on TE – Link Here](’
EKWB Dual Loop Liquid OC Modding Dream Kit - Closed Market Listings - TechEnclave’
