Help me pick a micro atx case
I have an rx7800xt, Deepcool ak620, and the weird CORSAIR RM850X shift PSU (side cables)
Im using the CORSAIR 400R and I find it a bit large for my usage. I want a smaller case.
I looked at the Lian li a3, but it would need some modding to get working. I want to ask you guys for advice because availability here is different vs outside India.
Im from around the MUMBAI area.
Look through this thread threadToMATXCases.
Does Ant eSports Box C Air @ 3.8k suit your needs or Deepcool CH260 but this is 7k cabinet.
I thought they would release CH260 for below 5k but not.
Main issue is my PSU cable situation. None of these will work. But thanks.
Tought So. Ask someone to make a bracket to shift the shift PSU (3D print it). Might acutally work.
Check these cases few of them are fish tank cases might work with Shift.
wow. thats a lot of options. Thanks!
Thanks, I think i will settle for the Antec
Nice to know. Any specific reason for the antec?
Seems to me it will have ample space for my PSU cables due to the case’ vertical orientation install.
