Hi everyone,I’m planning to set up an budget friendly NVR-based security system for my home and need some advice. I don’t have a concrete idea about the components I need or where to buy them at reasonable prices. Here’s my plan:
Installing at least 4 cameras (2 outdoors) to cover entry points, outdoor spaces, and the main hall, with plans to upgrade later.
I want a HDD that can store 14 days of footage.
Not sure what camera specs (resolution, FoV, etc.) or features (night vision, AI detection) I should prioritize.
I don’t know any reliable sources for quality parts at fair prices. Local retailers in my city quote absurdly high prices and often overcharge.
Questions I have:
Which NVR brands/models are beginner-friendly yet reliable?
What features should I look for in cameras?
How do I calculate storage capacity for 4-6 cameras running 24/7?
Any tips on cable management and camera placement?
Where can I buy these components at fair prices? Any trusted online stores or retailers in Tamil Nadu (or nearby)?
If you’ve set up an NVR system before, please share your recommendations or experiences. Links to helpful guides are also welcome!
Do you mind software NVR on a computer?
The features you need to decide based on where the cameras will be, the resolution will decide whether you will need 3TB HDD or till 10TB for 14 Days (if 24x7 recording)
Just saw this post. I have this exact same setup at my home!
I’m not sure if you’ve already made the purchases or if you’re still looking for suggestions, since this post is quite old now.
If you are, do let me know.
Hikvision is top tier! No wonder it’s working great.
For anyone coming across this later, you cannot go wrong with either Hikvision or Dahua. There are only some minor differences: Hikvision cameras have better support, quality, and resolution, while Dahuas are better in low light/night vision, and are relatively more affordable.
That said, I’ve been meaning to talk with someone who has an Omada or Ubiquiti CCTV setup. Hikvision/Dahua have great cameras, but their software can be a bit lacking. Wonder if these network-first manufacturers provide a better experience (probably won’t be as affordable though).
Either way, it was a local contractor who sorted all equipment and did the installation for me. All I did was make sure the equipment wasn’t terrible. And considering you are based in TN, I’m not sure he could be of much help (I’m on the opposite side of the country as you).
Apologies if this wasn’t much help.
DHI-NVR4108HS-4KS2/L
I changed my setup from DVR to NVR 3 years ago, which is when I got this. I’m sure there are better NVRs available now.
Get one with PoE included. This one doesn’t, so I had to get a separate switch with PoE for the cameras. Both setups are fine, but PoE included is cleaner obviously.
Oh and spec up. Adding cameras and wires is easy (and affordable), changing NVR is usually not. Better to get an 8 port even if you need 4 just in case you need to upgrade in the future. This is going to come in handy for us now since we’re planning on adding 3 more cameras and won’t have to buy another NVR.
