I need some help in decluttering the hardware I have hoarded.
I stay in 2 cities for work and hometown, but majorly in my work city.
Work city has a setup with
I9 14900K, RTX 3070, 64GB, but has a monitor with 1440p and 75hz, which I don’t plan to upgrade.
Hometown has a setup with
R7 5700X, RX 6800XT, 32GB, has a 4k 144Hz TV, which I often am not able to use to the fullest, hence play at 1440p 144Hz, even then I get like 70-80 fps max. Always play at ultra settings.
I got a good deal on a laptop with Razer blade 18, 13950Hx, RTX 4080, 32GB, so bought it quickly, without much thought. Work city has power connectivity issues, hence thought of using this laptop once I sell the PC. I have a 600VA UPS, but that doesn’t keep the PC on even for a second and I don’t plan to upgrade it.
None of the games I play have seen 100% usage on any CPU. Though 5700x shows its age with single core usage, but that’s manageable.
I have no usecase other than gaming for all this hardware.
Need your expert inputs on what hardware should I sell and what should I keep.
Note that I travel often (once a month), so carrying laptop is troublesome but not completely out of the picture.
Also, exchanging the work city and hometown PC except for GPU is something I am contemplating about. But will have to bear the shipping risk.
