i m sure there are many online sites which check your broadband connection speed and other details for free… can any one name one of them…
also add such links to the te recommendation thread na.. nothing much in that thread…
try dslreport first
you can also try airtel’s own b/w tester
reliable tests would be :
1.ADSL Guide with nice reports.
2.Bandwidth place with good comparisions and explanations.
Airtel’s B/w has given me good results, coz all the others hv tried showed a low speed, i mean they showed around 112kbps , 256kbps connection, airtel showed around 212kbps and +…
People asume that Airtel’s speed test shows speeds higher than it really is. I dont think so. Some tests show me quite low speeds. I have gopt fed up with this.
The tru way of knowing your speed is to download 3 files from a HTTP source and add the download rate of all three… This is the most accurate way of knowing your speed.
you can try testmy.net
true indeed …
if you are on airtel, then it will show the closest to the max speed possible. on my 256k connection, i get around 245k when running the airtel speed test
ADSLGuide is probably the best -gives me accurate results all the time - usually 1950kbps for a 2Meg Cable connection.
www.beelinebandwidthtest.com…i tested in this site…and i got around 1000 kbps..as the fastest
http://ciseweb100.cise-nsf.gov:7123/ This site is better than all the above sites. It is more accurate and can aslo give details like ur tcp settiings,check packet loss due to faulty wires and many more deatils all in one test.
nice dude ![]()
This one is one of the most accurate that i have come across…
My speed
I find speak easy to be the most accurate service for US. I think the best speed test is given by one’s own ISP from it’s local server. The best test of bandwidth would be from your local server to your home.
Here’s my speed..
Hi bluediamond,
You may check www.netlimiter.com.it has got various chart
and connection speed metres.however the download &upload speed shown
seems to be unreal you can rely on it for the downloaded,transmitted data to
your pc.though its a 28 days trailware there is a free version too.
softerman
You could also give the following one from Intel a shot -
Intel® Broadband Speed Test Measures Your Current Internet Speed
Speedtest.net - The Global Broadband Speed Test
try that one..
