RAM not running at specs using DOCP
So here are my specs , trying to get some life out of the system
Ryzen 2700X, Asus TUF B450 Plus Gaming, 4x8GB G.Skill Trident 3200, GTX1070
I recently had a lot of performance issues when I played games and saw that my memory was actually running at 2000MHz. Any attempts to select a higher value in the BIOS lead to a No Post situation. Now, I decide to test the system with just two memory sticks - matching channels. It clocks all the way to 3200MHz but crashes after playing games for 10 mins. Ive got it working fine at 3000Mhz @1.3v. But I wanna use my second set of sticks too. So I check the clock timings changes needed and I cannot for the life of me find the names of the parameters in the bios. Please help me understand the process a little better and get some more out of my PC until I can afford an upgrade. It would especially be helpful if you have the same or similar mobo and have attempted this.
Stick to XMP profile and if that doesn’t work, then don’t bother. Memory compatibility list is a thing.
Even at stock speeds you shouldn’t be having performance issues.
With DOCP enabled I can go upto 2666Mhz. That’s it. Was hoping faster memory, would help with some performance issues I’m having in game. The GPU seems green in the POE2 performance graph, but the CPU is always red.
What Fps are you getting in POE2 and at what resolution ?
