Questions
Q: What is your budget?
30K
CPU - P4 3.0GHz
Motherboard - Chinese (in place of Intel 865GBF)
GPU - Nvidia GeForce 6200
RAM - Kingston 512MB DDR1
Monitor - Samsung 17’ flat
SMPS - Zebronics 400W
HDD - 80GB IDE
Suggestion needed here, what I can make out is HDD and SMPS.
Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement. (In order of importance)
CPU
Motherboard
RAM
GPU
Cabinet
DVD-Writer
HDD (optional)
Yes, can upgrade HDD, RAM and GPU in future
Delhi
No
Programming on Microsoft tools like .NET, Visual Studio
Internet surfing
Watching movies
Running all the latest FPS games like COD4 MW2, etc. on ‘at least’ normal settings
Running tools like Adobe Photoshop and 3ds Max
Download rig, 24x7 operation
N/A
FPS - COD4 MW2 at normal settings
Racing - Grid/BP at normal settings
All - 1280x728
No, not atm
Windows 7
I intend to get this weekend itself, so I would really appreciate if I can have your suggestions ASAP. ![]()
Thanks a lot!
Cheers
