Review: Zalman Theatre 6 5.1 surround headset
Yes afaik u can configure the jacks to output surround sound but in the process u lose the mic input and line out.
lord dude…its doesn’t come with discrete jack…it has the usual ones, mic,output, n linein…n it doesn’t hv 7.1 output it has only 5.1…this is as per wat i hv on my system…i bought it wen 915gav chipset was newly out…thx hunt3r for ur hint…i think i got it…now only thing i wanna know i where can i get it in bangalore and for how much…right now i’m goin to SP to do some research letz c if i can hunt it down…thx again guyz for ur replies also wat i wanna is about other brands in the same surround headphones…also wanna know more about GAINWARD xPLOSION…any help is welcome
Well i havent seen them on SP road but i wasnt specifically looking for them so not sure. Check it out, you should get it though. Otherwise check out Computer shop on Brigade road, i saw them there. He does charge a bit higher tho so if you can get it from SP road its better.
Thx again hunt3r…will do so tomorrow…n then will update in here
awesome review dude!!
hey hunt3r…thx man i did find it at the ā€œCOMPUTER SHOPā€ at brigades…searched everywhere else they didn’t have it…n yes it just simply rocks…Thx everyone of u for guidin me to a good deal…i also bought myself ATP3…damn i’m bringing down the house…
Can u please share the details of the contact in bangalore where you got the Zalman Headphones.
