I am sure lot of us here on TE has on but i still se no review of the same. Post some details along with your respective rigs.
Example
CPU XXXX @ XXXX MHz
Mobo XXXXXX Chipset
Ram XXX MB
I am looking forward to buy one.
Thanks
Switch
Example
CPU XXXX @ XXXX MHz
Mobo XXXXXX Chipset
Ram XXX MB
Thanks
Switch
I have one in my work machine. So far so good. Its running pretty well. No issues. Overclocks to 580/1240. Runs whatever I throw on it without much trouble though anything that uses fp blends brings it to a crawl. The machine is AMD 64 3200+,(clawhammer @2.5 GHz), Asus K8N-E Deluxe, 3GB Transcend.
WOH!!! 3 GB… Thats some amount of RAM…
hehe there’s another winnie around that has 4 gigs :). I’d install more if i could get 2gig DDR400 sticks ![]()
Chaos why you need so much RAM… Whats your work about??? Just curious…
yeh lol
m thinking ram drive would be working just fine on ur pc eh ![]()
Whoa…3gb…dude lend me a gig for few days
..am on 512 rite now ![]()
well…nyways…just built this today after a loooooonf time…but damn happy
xfx 6600gt…working gud…even temps r on 51…so no probs thr…with 76.44 HD…wil try my fav games tmrw nd let u knw more
on 3000+ winnie…@stock…just said built today…so wil giv in sme burn-in time
DFI nforce4 ultra-d
graphics programming ![]()
I’ll lend u the ram… Lend me that board ![]()
Sure…
Now how much ram r v takin bout here???
great card. works fine. running it on default clock speed & ram speed.
not tried ocing since temp is on the higher side. maybe the temp is higher on the via board for this card.
all games works perfectly, doom3 & hl2 both @ 1600 & 8x aniso without any prob. although farcry wont work at 1600 that good.
What about your 3DMark’05 scores?
Which drivers r u using…AFAIK thr’s a temp bug in drivers …try sme newer drivers
Well this card works great for me ![]()
I have a slower proc compared to todays standards ;p
P4-2.4C Northwood
Intel 865g mobo (need to change that to overclock the p4, i hear it overclocks very well)
512mb ram (planning to double that soon)
right now using 66.93 since project snowblind doesnt work on newer drivers.
anyways the temp is always on the higher side with all drivers, this is always the case with via mobo’s even the processor runs a little hotter than compared to nforce.
anyways there arent any probs though of restarting etc. the threshold is 145.
Whts ur temps???..am having 50 on idle…
hey switch
gimme gimme gimme
ur 3dmark 2k5 score (6600gt)
{by the way psu was 16a}
Congrats Rocky ! What PSU are you using - 20/24/20-24pin adaptor ? And what RAM ?
temp is 60 - 65 on idle & i guess around 85 - 95 on full load, works fine though.
dunno y its so high, maybe its showing the temp incorrectly, or maybe its just that hot, doesnt matter though since it works perfectly & its got 3 year warranty.
but usually ive noticed from kt266 to kt800 all via boards seem to run processor at much higher temps than nforce boards, so i guess the gfx also might be running a bit hotter on the via board, cause i know other ppl with nforce3 & nforce2 whose temps are this high.
Yup…its showing temp incorrectly…AFAIK thr’s a temp bug in the WHQL drivers by nvidia…mayb they fixed it with thier latest release…
try sme other drivers..
btw which drivers r u using???
