Reviews/Experiences with XFX 6600 GT
Thnx maan…using a 400w 20 pin PSU.no adaptor either :blush:
running all this on the 400watter…
3000+
DFI nForce4 Ultra-D :grinning_face_with_smiling_eyes: :face_with_tongue: :jumpy:
256mb hynix d43 :rofl: …will get a gig in a day or 2. :smiling_face_with_sunglasses: :blush:
XFX 6600gt :clap:
4 HDD…samsung :wink:
1 Optical cd-writer
1 UV Fan
1 TRI-LED Fan
1 Thermal Control Fan :icecream:
2 CCFL UV Tubes :clap: :cloud9:
ALL running without ny issues yet :wink: :smiling_face_with_sunglasses: .. :touches wood:
^^Waaaay to go Man ! Can see that you’re on Cloud 9. Get her hot at stock speeds before you start riding her to Hi Heavens :wink: ! And a honest piece of advice though - don’t go barging in to dfistreet with a 20-pin psu blazing in your sig ! Seriously, those techies there will give you the cold shoulder. Just play it cool on that ! Anyways, good to know that you don’t have any kind of instability - there does appear to be many success stories with a 20-pin psu, but they usually get shouted down at dfistreet - hmmm…may be for a good reason !
Thnx maan…yup u r rite
the 1st thing they say if u hav a prob is …do u hav a 24 pin PSU :wink:
i didnt have ny issues as such except the ram
rejected my 512 mb ram…gav crashes
removed it nd now works like a charm…even on 256 mb ddr
yup…burning it up for a few days…will wait for sme time bfor OCing :smiling_face_with_sunglasses: :clap:
using 66.93
but had tried 4-5 other drivers also before this & all gave the same temp. so i guess all cant be wrong. anyways temp isnt of any concern since it works fine.
how are the new nvidia drivers. working fine?
Well all drivers frm nvidia r temp bugged…so thr u go
also try the 76.44 HD…really gud nd also temp bug is fixed…
All the drivers except the non-whql nd 76.xx r temp Bug fixed
Temp bus is only present in drivers newer than 71.20 and older than 71.89.
6x.xx series doesnt have the bug afaik.
so which drivers to use?
the new1’s on the nvidia site are also temp bugged?
71.89’s don’t have the temp bug.
If snowblind doesn’t work with the new drivers for you, stick with 66.93 or the 67.66 official betas.
Hardly any changes in performance between drivers except in ut2k4.
