Just got the Chip April 2005 edition and installed the SC : CT demo. Just for kicks, I turned up all the options to max, resolution to 1280x1024, Shader model to 3.0 and HDR On. When I run the game, Fraps tells me that the frame rate is a niggardly 16 FPS :huh: , sometimes 25 FPS. Switching HDR off will increase the FPS to about 25 minimum to 35 maximum, but switching 4x AA on will pull it back to around 20 FPS.
Is this OK for my rig? I have a feeling that I am missing out on something. What I have is:
AMD 64 3000+ (S 754)
ASUS K8N-E Deluxe
XFX 6600 GT AGP 8x
Hynix 512 x 2 PC3200 RAM
Seagate 80GB SATA HDD
Windows XP
All the latest mobo drivers
71.84 WHQL Official
In comparison, Doom 3 1280x1024 High with 4xAA gives me about 45 FPS and HL 2 1280x1024 High with 4x AA gives me between 50-70 FPS.
HDR and all those wonderful effects of SM 3.0 are causing the slow down of the game. The current gen of nvidia cards is probably not capable of handling all of this. Try switching to SM 1.1 thru console if there is such an option and blame Nvidia for making a paper-only SM 3.0 card
Like Blade_runner said Nvidia cards are only Paper SM 3.0 products turn off HDR lightning. Also that game requires atleast a X800XL or a 6800 GT to play with AA and AF on. All said it plays a lot better then my 9800 pro which struggles on 1024 also on a similar rig.
@Blade_Runner, yes that game has an option to switch from SM 3.0 to SM 1.1. I will try that and see if there is any difference in the frame rates.
But FarCry 1.3 also uses SM 3.0 and works pretty good, FPS always > 30 even during intensive combat and the super-shader intensive Volcano level. That is with 4x AA on. Removing AA increases the FPS to about 40-42 steady. Of course, switching on HDR makes my 6600GT struggle a bit.
Maybe it is the Unreal 3 engine that is not implementing SM 3.0 so well.
@hardboy, please note that we are talking about Chaos Theory here, not Pandora Tomorrow. My rigs does Pandora Tomorrow at 1280x1024 with 45 FPS minimum. Cant check with AA since the game does not support it. How does your rig do Chaos Theory? That is more important here.
BTW, my XFX has 1000MHz memory and we are not discussing whether 9800 is better than 6600. That has been done to death everywhere. Anyway, Aces170 said (just three posts above):
Huh, is Chaos theory based on Unreal 3 engine, and no its not the engine but the hardware that lacks the punch. Maybe the next genration G70 and R520 will display playable SM 3.0 enhancements like HDR lightning etc
I guess not, my bad. It seems to be just an updated version of the engine used by Pandora Tomorrow, which I think is Unreal 2. Sometimes I get an error message which goes something like LoadData<-Unreal::BeginLoop<-Unreal::Tick or similar. That is an Unreal 2 engine error, since I used to get the same type of message in Unreal 2.
Chaos Theory is unreal warfare only I think, just a newer build. Not sure.
Splinter Cell games always favour graphics over performance, all of them perform equally bad.
lol I noticed a performance gain of 10fps between my 8500 and 9800 pro in pandora tomorrow, only difference was with the 9800 pro I could apply some aa.
Also if you chose to use ps1.1 in ct, you will get some ugly texture banding.
what ? your enabling HDR ( high definition ranging ? ) . thats a bit too much for your card and that too in max. resolution . turn down some options ( reduce the resolution and image quality maybe ) . Splinter cell - chaos theory is too much for 6600GT i tell you .
Right, I am now running the game on SM 1.1 and the FPS jumped from 15-20 to 25-30, without AA. No banding of any kind seems to be visible. Take a look at the two images below. The first one is SM 1.1 and the second one is SM 3.0 with no AA/AF in either case. The FPS difference is obvious. I have scaled the images down from 1280x1024 to a much smaller size.
Edit: Oops, the images seem to ahve switched around.
@saumil, if you are talking about the image in the Beyond3D forums, yes that seems to have heavy banding. I am not seeing anything like that here. Maybe that appeared since the game was still in development at that time. Must have improved it before final release.
Must be ATI specific, since I am seeing no banding whatsoever. The screenies I posted speak for themselves. I can post more screenies taken in different areas, if anybody wants, just to show the absence of this “banding”.
Any nVidia guys around here getting banding in this game with SM 1.1? How about the ATI crowd?
