I have two machines connected to it, a desktop with Ryzen 7600 and Nvidia 3060Ti (might upgrade to RTX 4090/5090 later this year for LLMs) and Macbook Pro M2 (for work).
Right now, it is cumbersome to switch between the two. I want the display, keyboard and mouse all 3 switching to either with just one switch.
I need a KVM that can handle at least 4K@120Hz (i.e. 8K@60Hz) with EDID support. Most listings on Amazon are limited to 4K@60hz and EDID is lacking.
I’ve used generic KVMs before and many of them either lagged or went blank while switching and had to switch back and forth 2-3 times to get it working.
If anyone is using a high performing KVM, please suggest a model and where to buy it from. Budget is not an issue, but it should be reasonable and not crazy.
Without EDID emulation, the resolution, refresh rate, and monitor position will not be remembered when switching back and forth between computers. So I need that feature as a must. I also don’t need 3-4 PCs, just 2 simultaneous PCs will do the job for me.
This is what I am looking at:
But it’s quite pricey and will have the importing headache plus duty. Hence, the search for an affordable alternative.
My search ended up with no option. There are some 4K 60Hz KVM switch for 5k+, which might be enough for my 1440p 170Hz monitor but decided to buy a simple USB switcher for 1k instead as there was concern about VRR as well. I just have to connect 2 cables to the office laptop & press 1 switch when I want to use it with my monitors & KB+mouse.
