TP-link JetStream 8-Port Gigabit Smart PoE Switch with 2 SFP Slots @3k
https://www.flipkart.com/p/p/item?pid=ACPF5YYMX9GAGHZM
showing me
OOS
Lovely, thanks
Available at certain pincodes
Great deal, thanks!
understood
POE switch. So, you can use this switch to directly power your poe devices like an IP camera.
Managed gigabit switches alone cost around 2.5K on average, for extra 600 or so you get one with 2 SFP ports.
Shows available to me, let me know if anyone wants. Can re-ship after receiving (+shipping would be ~₹200)
Is it a steal deal at this price?
Can’t say steal deal, locally this is always avilable for 4.5k , so 700 rs saving.
The flipkart Axis card means at least a ₹150 cashback and like you say ₹4500 locally. it’s at least a ₹1600 savings!
I think I can even get it with 10% cashback if it’s available.
Yes , correct didn’t notice it’s 3k now , had put it in cart when it was 3.8k
so, what do you say if i were to get it for 2700 effective cost? ± 50.
It’s a good deal , but you will get mostly 2 to 3 years old product , so consider it out of warranty. If its okay they you should buy it.
Does TP-Link honor the warranty if their official page says the product is EOL’d? Guessing they should (edit: given selling as new here?).
Interesting.
If it goes bad then we get a newer version/release similar product?
Flipkart will sell even 3 years old sealed product as “new” on which brand might not even give any warranty.
Same product most likely assuming you even get full warranty from date of purchase & not date of mfg (see above).
Are we sure that the product listed here is EOL ?
The product images show MP version and the image also shows a full sized power socket instead of a dc plug in the linked version and MP version also has higher power budget.
It could be misleading product image. I have ordered one and its an open box delivery, so if it doesn’t match description I may reject citing the mismatch.
Is it worth keeping even if its the EOL version ?
Never tried buying a fresh EOL’d TP-Link device but you can see if you can register for warranty after yours arrive. Otherwise, just have to hope you are indeed getting a fresh unit that might last longer than a used one.
Flipkart details are lacking indeed so probably note down the possible variants and how you can differentiate during open box.
I have bought eol tp link router from Flipkart earlier. I was able to register the warranty for it with the bill although never had to experience RMA.
