3d work station_need help
kalla_maakri said:
wots happening....y no one is Suggesting me good rig..pls help no..wot is happening to techenclave..!!no one is here 2 help me out!!! :huh::ashamed:
Its you that is "happening".
Either:-
a) Increase your budget to accommodate a pro-card.
OR
b) Go with the suggestions already provided.
OR
If you have any particular doubts, explain them in detail.
NOW Wot is my problem!!!:ohyeah:..i hav askd for complete rig..no one suggest a full rig(leave the budget abt pro_card..any one cud suggest abt other components no!!!??)nd the best part is i got an entry level pro- card in my budget,now wot u can say abt pro-card budget :) LOL)..one person mention abt one procy.. nothing else(go threw the post ..can u c a single reply with a complete rig suggestion!?... ) finally i only came up with full rig !!!still no reply....
Amien said:
I
Either:-
Which suggestions!!!!?????????????????????????????????????????????
i needed a complete rig succession..man at least dont blame me ..:ashamed:
dont go for i5 ... you need a serious quad core for your work thats why I suggested core i7 .. to be specific the lowest model 920 which is for ~14k ... 6gb ram at decend 1.3ghz will do you can always oc and go for a stable mobo with which you can oc ur i7 to get max performace . now gpu is upto you so ermm yea .
