rohan_mhtr
Explorer
15-16k on speaker + soundcard ! Is it worth it ? If you add just 3-4k more you can get an entry level AVR+speaker pack . Also can check used adds
you could try wall hooks or temporary/simple shelving.But doesn't make sense to get stands worth 2k for speakers costing 4k
Yup I guess diy is the only way to go.. I'm thinking of PVC pipes [emoji14]you could try wall hooks or temporary/simple shelving.
otherwise you could get the stands made by a carpenter.
I have a five years old Philips sp100..which speakers did you get? if not in a rented home, using wall-mounts like those from 'Tono Systems' and concealing the cables using casing-and-capping would make for better looks and handling.
