Graphic Cards 7600 GT problem
you used to get the message with older drivers too ?? ..try some 80 series drivers 91 & 92 series still have got some issues
If games are fine, don't worry too much. As i also mentioned, the message used to come all the time for me using a 5900xt.
kya pata kabhi windows bhi yeda hota.
Is there any "PEG link mode" option in the bios ??...... if yes then try changing that .....
What's a PEG link mode???? i dont wanna dabble too much in the bios..... unless I'm pretty sure what i'm doin.....
And i've got 91 series driver.
u ain't gonna mess anything .... unless and untill u are playing with voltages and i don't think much options are there in VM models .....
PEG link mode has to do something with the interface of the graphics card with PCIe slot ....... don't remember
Why don't you actually check the bios, insted of checking the specs on the site...anyway try getting hold of the 80 series drivers. Think it's just a software/driver error anyway, don't worry too much as long as the temps and fps are good enough
sultanofswing said:
OK... I'll see what to do.... but 80 series driver... izzat really necessary?
I used to get the card not working in Sli mode message everytime when windows started with the 91.xx series drivers even though my board is non sli, no such message with the 84 series and 92 series .
I get that message too!!! ok....I'll first chek on th PEG thingy.... then download 80 series drivers if necessary....
