Any tax expert here.....need help with choosing ITR-1 or ITR-2
You just have to re-send it. You revise it only when you have to change something from your original return.
Can you explain more on this, I happened to omit my investements and pressed the submit button on Quick ITR, now if I don't send the printout and file another one, should I upload it as revised or as original?
If you are asking about revised return then there's a field specifically meant for this purpose in the form... you need to select whether you are filing an original or revised return.
