AOC 24" lcd monitor review.
Introduction
I was looking for two 24" lcd display one for my cousin and one for myself. He is into gaming and movies (like most 14 yrs usually are), so a TN panel with good response time is what I was looking for. I wanted to get him a 22" but he insisted on a 24".
So after a long search, finally short listed Dell E248WFP, Samsung 245BW and AOC 416V. Dell quoted 24k, Samsung was not available and got a nice price of 19k for the AOC. My friend had recently bought this and I was really impressed by its performance.
So went for the AOC 416V. It's actual market price is 20.5k + VAT (that brings it around 21k including the taxi fare :D ) I got it for 19k inclusive of all, through my friend and his "contacts".
Okies......too much talking, lets get down to the business.
[BREAK=Packaging]
Packaging
The box is pretty small for a 24" lcd and its the usual brown box with details of its contents like monitor size, resolution, weight etc.
The packaging is pretty compact with the display protected from the top and bottom by thermocol.
The package includes:
24" lcd display
Stand/Base
VGA cable
DVI cable
Power cord
Driver CD (The manual is included in the disk/no paper manual)
A clamp thingy for cable management.
Printed insruction as to how to setup the monitor.
A leaflet mentioning the the display TCO'03 certified.
[BREAK=Initial Impressions]
Now the monitor itself.
It has the basic VGA and DVI input and the screen is covered with a thin plactic sheet to protect the screen.
The monitor in action :D
The OSD bottons are located in the front which include source, auto, forward, back, menu and power button.
For details about the specification for 416V visit the AOC site : :: AOC India, " From the Worlds Largest manufacturers of Computer Monitors "
The monitor is pre-callibrated for you to just connect and happy computing.
[BREAK=Further Tests, Gaming and Movies]
As for test I ran the everest monitor daigonostics and displaymate. The colors are simply amazing and the text is sharp. There is a ever slight mismatch in the grey levels but compared to the regular TN panel this one is a level above others. As the spec. mention the 16.7M colors difference can been seen compared to the regular TN panels 16.2 colors. I know it is done through dithering but still the image quality is better than the Samsung 940BW and Benq FP92W which I had sold recently.
The Viewing angles are good, keeping in mind that it's a TN panel and if you move beyond 155-160 degree the image does start to become haze. But if you sit in front of the display like I am used to, then there is no problem.
As for ghosting and blurry image, there is none. The 5ms response time does help. I tried COD4, Gears of War and Test Drive Unlimited.
Backlight bleeding is non existence and didnot find any dead/stuck pixel.
For movies I used the HD showacse video and few HD movies like Borne Ultimatum, Transformers all 1080p
This is how a 720p video looks on a 1920*1200 display
[BREAK=Conclusion]
Overall, the monitor is value for money which saisfies all you regular, gaming and movie usage. Moreover the price is good. I am also waiting to get a 24 incher for myself and after seeing this one in action I am also thinking of getting one.
To summarize:
PROS
Large work space
Vivid colors
Good viewing angle, keeping in mind that it's a TN panel.
Lots of setting for those who a ready to callibrate the display to its last details.
Easy to understand OSD.
Very thin bezel.
No ghosting or blurry image.
No backlight bleeding.
CONS
No height or swiel adjustment.
Less viewing angle compared to the MVA,PVA etc panels.(But not a issue for me)
If I have missed some points please feel free to ask me.
Thank you for reading through my review.
Reactions: 7 people
john_tigga said:
Other option that's currently available in the market could be LGL245WP it's an MVA panel, Acer 26" it's a PVA panel priced 37k + tax or wait for Dell E2408WFP.
There's not a huge difference between 720p and 1080p. Both look extremely good but 1080p does look crisp than 720p. The monitor scales the video perfectly, even DVDs look ok.
But 1080p does takes the first spot. :hap2:
Thanxxxx mate.... actually I am waiting for that particular DELL model... if the price is right & budget is favorable to LCD panels then it would be a great buy...
I have seen screenshots for 720p & 1080p encodes & find the 720p ones a bit grainy & matted compared to 1080p... May be I noticed too much but still I personally do prefer full HD over half HD any day.....:hap2:
hmm, this might be my next purchase.
i am confused between a 24" monitor or a 32" LCD TV.
viewing distance at the max is 8 feet.
john a few questions - can you tell me the dimensions of the screen alone?
and a if possible could you take a snap with a keyboard infront of the screen?
Also, from where can one get a vesa 100 wall mount?
and who wins if Dell vs AOC?
Thanks again.
The screen without the bezel is (WxH) 20.6 x 12.9 inches. Daigonally the lenght is 24.2 inches.
WIth bezel its(WxH) 22.1x 15.4 inches. As you can see the bezel on three sides are really narrow and the bottom one is a bit wide.
Height with stand is 18 inches.
Here goes the snap with the keyboard, the keyboard is facing the wrong way :D did this to take the photo.
You can get it any shop dealing with lcd tv. As to who wins is debatable. On paper both have almost same specs, that's for E248WFP.
See this PRAD | Result LCD-Monitor Comparison
As for Dell E2408WFP is/will be in the league of its own. Can't just compare a TN panel with S-PVA.
Hmm...its priced at 699$...It may well be an S-PVA...
Do you guys think I could swap my 2407WFP-HC for 2408WFP by claiming warranty :P
Yes it'll be fine at 8ft (viewing movies/gaming but not for web browsing etc.). I usually watch movies from a distance of 9ft approx and it looks damn nice, specially 1080p. At that distance the text are really hard to read ;)
As for wall mount any vesa 100 compliant system will do.....just watchout for the mount's weight capacity. This particular monitor is 7.5kg
Nice value for money monitor.
The not so good point is that it does not have HDMI,Component Video, and S-video inputs.With HD/HDCP capability, one would naturally look for them.
Can it replace the HDTV when coupled with a Media Center PC? I took a hard look at it and here is one user's comment.
"just bought a AOC 24" from IT Estate. It's OK, but after using it a bit I'm a little disappointed at the quality. I expected a better picture as it's 1900x1200 resolution. I also miss the "i" key button on the BenQ so that it automatically sets everything up. Doing it all manually is a pain. I use it as a XP Media Centre PC monitor - and things like photos and 300x300 HQ Album Art looks good. Just video and HD TV look crap. Also, MCE is in 16:9, while the AOC is 16:10 so you have black bars on the top and bottom... "
Not-withstanding, it is an awesome PC Monitor.
what ll be the price point of Dell E2408WFP ????
and when ll it be acailable from indian markets????
is this different from E248wfp model ??? E248wfp model is 18 k ryt ?
