    Sincerely,
    The TechEnclave Team
FS: Others APC br1500g-in, 15.6 diy monitor, TP link wr740-n, Gelid GP-extreme thermal pads, thermal paste
lazyman
Feedback: +7 / =0 / -0
NOIDA
3 out of 5
  1. Bank Transfer
Excluded - at actuals
None
No
Not needed
Product Name: APC BR1500g-in
Expected Price: Rs 7500
Manufacturer page URL: https://www.apc.com/in/en/product/B...ian-outlets-avr-lcd-user-replaceable-battery/
Description:
Went faulty in June 2022 with f2 error. Apc quoted 12k for repairs and advised to buy new system instead. So, I cut it's wire cord and used in the inverter system bough to replace it. Later while trying to sell battery I found out it can be repaired by local apc partner. Got it repaired for 5.5k. Battery was replaced around March 2022 with original apc battery for Rs 4500. Only remaining concern was the battery extension connector port was sometimes lose and had to be pushed in. They weren't able to fix it in previous repairs but fixed in last repair.
Local pickup preferred as not sure if shipping with battery is safe.
Reason for Sale: Bought inverter system, since I thought ups can't be repaired. Now the ups overloads the inverter and is redundant. Only benefit is that the system shut downs with inverter if gaming at full load but not with apc ups.
Product condition: 5 out 10
Purchase Date: 2018 December
Remaining Warranty period: None
Invoice Available: No
Product Name: APC BR24bpg-in
Expected Price: Rs 5200
Manufacturer page URL: https://www.apc.com/in/en/product/BR24BPG-IN/backups-pro-external-battery-pack-24v-india/
Description: Battery extension pack for APC BR1500g-in. Triples the battery capacity. Local pickup preferred as not sure if shipping with battery is safe.
Reason for Sale: Selling since no longer using ups.
Product condition: 7 out 10
Purchase Date: 2021 October
Product Name: 15.6 inch diy ips monitor
Expected Price: Rs 2900
Description: 15.6inch 6 bit ips monitor. Should enable dithering in Nvidia as it is a 6 bit panel. Bottom Frame is not sturdy and should be replaced with your own diy solution. Back frame of panel is good and can be reused. Control board takes hdmi input and power from included adapter. Doesn't allow brightness change and display only(No additional audio output from control board). From memory I recall the panel being B156han01.2. Bought from ali express when it worked. Local pickup preferred as fragile for shipping and don't have a perfect box for it.
Reason for Sale: Used only for a month or 2. Sitting unused since 2-3 years.
Purchase Date: 2019
Product Name: Gelid GP-extreme thermal pads
Expected Price: Rs 2800
Description: 3x 0.5mm, 3x 1mm, 1x 1.5mm Gelid GP-extreme thermal pads. Size 80x40 mm.
Reason for Sale: Bought for repadding laptop, but laptop was sold in warranty.
Product condition: 8 out 10
Purchase Date: 2019
Product Name: TP-link wr740n
Expected Price: Rs 250
Description: TP-link wr740n router. Works as 2.4ghz router or repeater.
Reason for Sale: Not needed
Purchase Date: 2017
Product Name: Cooler Master Thermal fusion paste
Expected Price: Rs 80
Description: Cooler Master Thermal fusion paste.
Product condition: 9 out 10
Purchase Date: 2019
I know that you are trying to sell the DIY monitor as a package and local preferred. If you decide to sell the HDMI/Video control board, please let me know.
Have repaired two APCs (1000g-in, 1500g-in) with f2 and f4 errors myself in the past. 5.5k is a bit high amount, unless he replaced the whole board. The batteries in these can be replaced with aftermarket (Exide, Amaron) batteries also. The external battery pack uses four of these batteries while the ups itself has two batteries connected in series.
Yes, they did replace the pcb, fan and another connector. I think it wasn't a pcb issue as it wasn't fixed by just replacng pcb, but that's what they claimed and I had to pay. Initial quote was 4k for pcb but then they added fan and battery connector too increasing cost to 5.5k. If I knew you could repair it, would have contacted you.
Price Drop:
APC BR1500g-in: Rs 6500
APC BR24bpg-in: Rs 4500
15.6 inch diy ips monitor: Rs 2600
Gelid GP-extreme thermal pads: Rs 2450 Sold
TP-link wr740n: Rs 200
