You need to use Microsoft's RRAS service for this. You need to install it from the Windows Components in Add/Remove apps.
Yes. By default, RRAS is installed but not enabled or configured.cricfan said:isnt it available by default.....
spynic said:yup guys it works.. but about the server... should i hook it up on a wan port...?? or lan?
