PC Peripherals Cabinet - Cooler Master or zebronics?
why 330 NOW when now u can get 334 or 335 which look so cool at just 2100 or 2050 form prime in mumbai
for the fans go for so 300 bugs amigo 120mm fans
Is Cooler Master Extreme power series so bad?My budget is 3k max for PSU so i decided CM 500W.Here in Lucknow it will cost aboutt 3.1k.I will run 9600GT and I believe CM 500W will be more than enough for it.About Tagan PSU,never heard of it in real life.My other alterntive was Zebronics PSU which was labled 80% efficient and costs about 3k.
^The Extreme Power 600W was over-rated. Although this might not be the case with all the PSUs in the EP league, you'd betetr stay clear from the Extreme Power PSUs considering 3k would get you a Corsair VCX400 or a Tagan 500W which're better PSUs, in fact miles ahead of the EP 500W.
Ok I will see if I can get Tagan.By the way is there any way I can disable these advertisements I see between the posts.:P
