Car Audio System
VOiLA
Contributor
hi again :tongue:
now i need a car audio config :ohyeah:
i really dont know about car audio stuff...so dont get mad @ me lol
budget is 2.5grands us$ will purchase from newegg or anywhere else... :bleh:
so this is what i am looking for....
deck - mp3,cd player and shd be compatible with cowon d2 player or ipod ;)
front speakers/rear speakers/amp/sub/tweeter and all u can suggest me !!
PS. i want boooooooming sound !! my frend in USA got a sytem with 4 amps 4 woofers (all sony xplode) (4 or 5 channel system i guess i donno exactly) i dont care.....but remeber my budget !!
also, what do u say about hertz sub ? and a bass tube ?? anyways, need a good config !!
2.5 grand it means approx 100k INR...
for this I would go with the folowing..
HU-> 7950 for 9k (it has USB support)
Amp-> JBL 75.4 or GZTA 4.120MK² for speakers (10k)
Components for front -> Illusion Audio Electra or Luccent Series (6.5k or 11.5k)
For the rear speaker I would to drop the idea as I dont like the idea of sound coming from the back.
Sub woofer amp -> two pioneer D510 or single JBL 1201 or Alpine MRD 1005 for (20k)
Sub-> GZRW 12 XD-AL Ground Zero sub (solid SPL)12k
total.
9+10+6.5+20+12+12=69.5
or
9+10+11.5+20+12+12=74.5
in the above the HU and the sub amp is in grey rest the stuff is with B/W
also the stuff which is with b/w if you source them for outside india it will cost you expensive.
other than above we would need cables like power , RCA and Speaker I would allocate approx 5k for the same.
and with two sub in the boot some damping is also required, and a enclosure. I would allocate a 5k here also
so the final budget would be approx 85k which leaves you with 15k.:tongue:
alright...but i need rear speakers too..suggest me ....and how about going for 5/6 channel setup ?
and can u gimme the links to the sub ? i googled it but im unable 2 find :(
why do you require a 5/6 channel setup..??? or what do you mean by that.
this what ground zero is all about ....total SPL...
177 db for a single sub..which other company uses more than 9 or more sub woofer to produce....
::: Official Ground Zero Team Page::: News & Pics
this is the sub I am talking about..
:: Ground Zero :: Subwoofer / GZRW 12XD-AL
it has a XMAX of 18 mm means that it can push lots of air and air displaced is SPL
VOiLA said:
...cant find it on newegg/amzon too...do u guyz know any car shopping site ??
//thanks
Why do you want to get the stuff from the net it will cost you more as there is customs on the car audio stuff..
alright, by 5/6 channel i meant for the car obviously...will it make a diff ?
and pls temme setup for rear speakers too
and wts this a 10000 wtss rms woofer woowww GZPW 18SPL
http://www.team-ground-zero.com/equipment.htm
//thanks a lot man
::: Official Ground Zero Team Page::: Equipment
//thanks a lot man
yes there are 5/6 channel amps available but the wattages are quite less. to do the sub woofer job..and these models are quite less made. for your job you need a 4 channel amp as you also need speakers in the back , and a mono block for the sub duty. as you need two subs then two mono to get max output.
JBL Car & Marine Audio
for the rear speakers you can put one more component kit in the back for the same...
budget 85+11.5 = 95 k still leaves you with 5k..
ya that is one soild sub and cost above 1 lac for a single pc.
Reactions: 1 person
:tongue:
OKAY >>> can u pls give me the links to JBL 1201 or Alpine MRD 1005 sub for the woffer if i go with the 12xd-al sub
or
can i install this sub+amp combo instead of the previous config ?
GZPA 1.2750SPL amp (1 pc.)
GZPW 12SPL sub woofer (1 pc.)
and
front+rear speakers+ the GZTA 4.120MK² for speakers (1 amp for both frnt+rear speakers or 1 for each ? =2 ?)
+ wt abt tweeters ?
//thanks so much bro :D
VOiLA said:
:tongue:
or
and
+ wt abt tweeters ?
JBL 1201.1
Alpine 1005
Alpine MRD-M1005 Mono subwoofer amplifier 700 watts RMS x 1 at Crutchfield.com
for the
they are not launched yet but you can go for the same if budget allows..
GZNW 12SPL -> 60k
GZPA 1.8000D -> 195k
for speakers one amp is enough as it is a 4 channel amp...
and the tweeters come along the component kit.
Reactions: 1 person
Dude.. u need to be looking @ Sounddomain.com
Also I would say competition series subs from Rockford-Fosgate and JL Audio's 12W7 will kick some nice LOW-butt... but then its costing a bomb too :P
JBL 1201.1
Alpine 1005
for the
GZNW 12SPL -> 60k
alright, gr8 !! but there is no 1.8000UD model there...its GZPA 1.6000D i guess...right ??
and pls pls give me the link to the front+rear speakers...Luccent series or/and the other one ...
//thanks
Hmm...what do you want in your HU...
well..like i told u i don have much knowledge abt all these so kindly educate me...wat all features can i get within 10k....it shd have usb support i.e for cowon/ipod...
//thanks
//thanks
the 7950 is the best bet with lots of good features....
where do you put up Delhi or where...
