PC Peripherals Choice of Cabinet+ heatsink+fan+thermal paste
Blugene
Contributor
Hi!
I'd really appreciate if you cud help me with the following....
well tmrw i'm gonna go hunt for a decent cabinet & heatsink+fan+thermal paste for my pc with prescott 3.0GHz which sadly is giving me sleepless nights with its high temp...( idle temp arnd 56-58'c)....forget abt paying games ...i can't even fwd divx movies without the temp reaching 70'c.
Anyways i'v decided on a zebronics london series cabinet with 2 120mm fans ( 1 for intake & 1 for blowing air out..) + 400W powersafe PSU...+ artic silver 5 ....if you have something better in mind do post your comments...Btw my budget is arnd say 4000 bucks.
the above would do? or do i need to get a separate heatsink like cooler master vertex dream or hyper6....and if you do recommend the same and if you know where to get them @lamington road....plz let me know...
thanks.
well ive got a Thermaltake spark7 heatsink for sale, all copper, there is a link in TE market about the same
and mumbai guys will be in a better position to help you with the shop details..
Well i would suggest getting a third party cooler like CM Hyper48 or Hyper 6+ ...
Also Powersafe 400W is a good choice.
For Cabinet, i would suggest, VIP ZB-01 or Zebronics Jamainca/Pyramid Case. All are the same from inside except for the Bezel.
Also going for AS5 is a good thing,should help you in keeping your Prescott cool.
thanks guys...i was just wondering if it would be better off with 2 120mm fans ( zebronics London Gold Series) or 1 120mm( rear of cabinet) and 2 side fans ( LAVA series cabinets) ?......also if u could let me know where to get those Coolermaster products in lamington road ( mumbai) ...
