Wraith said:Does moving the display cable in certain postions help? if it does then its time to change the cable....
I just switch off the monitor and swithc it on again after 2-3 mins.... Works perfectly fine...
Nikhil said:GOD!!! this is hilarious!!!
Actually made me laugh aloud!!!
Well, I have also had that problem once in a way. Sometimes when the monitor is switched on and I move the monitor, like rotating it to make sure someone sitting on the bed can see it, I see that discolouration near the edges.
QuickFire said:The display problem is back...bluish screen
changed the DVI VGA connector. also changed the port..using the 2nd port currently...it was fine for last 2 weeks...now its causing probs again.
help plz. :S
Switch said:Okey this might sound weired but are you using a SATA HDD... If yes then change the SATA Cable...
now I know for sure its not a monitor problem.hunt3r said:Theres always the slap, boom bang method
how does a changing a sata cable correct a moniter problemSwitch said:Okey this might sound weired but are you using a SATA HDD... If yes then change the SATA Cable...
DarkNight said:Mr. Wadhwa...why are your solutions so tedious....
Dude - The best and easiest solution...Disconnect the monitor, unplug the pc....now stretch the cabling of the monitor a bit.
Carry both to the nearest windows and test to see if the laws of gravity still apply.....
